On my 72 EC 402bb If I wanted to change the intaketo a hi rise will the cowl air cleaner still fit.Or will I need to use a std type air cleaner???? I think I may have a Sq.port intake on my oval heads!!!!
I think that is one you should be able to handle as we don't know what intake you're planning to use. The stock low rise intake uses a spacer to fit the air cleaner to the hood. If the installed intake height difference is less than or equal to the now-not-needed spacer then you're in luck.
