The car starts fine, however on some starts, there is a sound I can't even explain. Not a grinding noise, not a squeal. I've been reading up on starter shimming and I'm leaning that way. Question is: does the pin I need to measure the armature/ ring gear tooth apply in my case. Haven't pulled the starter yet to check condition.
BTW, Welcome to TC. :thumbsup: Tracy,, are you using the correct starter bolts that have the knurled shank on them ? or are they just regular store bought bolts ? Regular bolts are no good for your 454.
Just use a 1/8" drill bit. Jim
