I'm beginning to set up a tach dash I purchased for my '69. I'm trying to determine the the proper sending unit for the oil pressure.
I'm looking a piece that is in an AC Delco box, and supposedly for a '69. It has '80', and then some other numbers stamped on the side ... so I think I'm looking the right direction.
Can anybody tell me what the AC Delco part number should be?
And, Are '69s special sending units ... I see that Ground Up sells a "69 Oil Pressure Sending Unit", which usually means 70+ are different?
Thanks, Neal
69 is special because pre 69 all use mechanical oil pressure gauges, 70 - 72 have an oil pressure indication light - no gauge. The GM part # is 6461928 two other numbers that I understand will work 6462137 or 370801 I can't guarintee the last two #s but I can guarintee the first # will be very hard to find.
