A buddy is working on his 69 elky, can anyone tell if wheel opening moldings were availible on thesefrom the factory and if so who sells a good set, also he will be puting a big block in this, will he need to change the engine mounts on the crossmember its a small block now. Thanks Don
From reading they where. I think finding original ones around would fit best but think just everyone carries them. There might be a problem with the side trim if you have it,being to long to fit wheel ones on if they weren't allready on it.
The wheel housing trim was standard on the 69- 13680 bodys. The trim is the same on Sta. Wgns. I do believe it is repoed.
Bob
