I stripped my door panels and re used the original metal top pieces and bought the door panels that were not pre-assembled with the top metal in them, its a little more work but is much better fit.
I used the PUI and was happy with them. Or you can also get them from http://www.legendaryautointeriors.com/ The only reason I used PUI is because legendary did not have them in production for Chevelle.
Most of the users on this site will say to use the legendary:yes:
· Lifetime Founding Member
If you're careful you can glue the mylar back in place. Both my "popular brand" '69 door panels had the chrome strips come loose at the bends. I glued them back with 3M HD spray adhesive brushed onto the backside of the strips.
