Hey guys, a quick question, hope somebody can help. If you are gonna remove the clock and radio in a '69 SS, do you have to remove the dash bezel or can you get them out just from under the dash?
Hey thanks for the info. Just how difficult is it to remove the dash bezel? Is it worth it to get the clock out and try to repair it, meaning even after it is repaired, will it usually stop working again or are the clocks fairly dependable afterwards? I have not seen any aftermarket 69 clocks offered, so I am assuming you have to have one fixed. Anybody done this and regretted it or done it and loved it??
I can tell you this much from Experience its a lot easier to remove the entire wire harness with the entire plastic dash, kinda like plug and play:yes:
You might be able to take all the screws out of the dash and tilt it forward to get to the clock but I doubt that because their is not enough play in the wire, I have been their done it.
Here is a few links of what you are dealing with.
http://s193.photobucket.com/albums/z238/1badss396/TEMP FOLDER/
http://s193.photobucket.com/albums/z238/1badss396/69 Guages/
