The previous owner put new door glass in the doors but did a poor job of aligning them. The glass in the passenger door overlaps the rear glass at the top and the drivers door glass sticks up 1/2 inch when rolled all the way down.
I have no experience in door panel removal or glass alignment. Is this something better left to a shop ?
Thanks.
You might want to get the body by fisher book, sure helped me on doing my window glass. But once you do one window of each kind its a breeze to do it again.:yes:
You might be over your head on this one since you need to pull the back seat, all 4 door panels, and then start tweeking the adjustments. There are plenty of adjustments that can be moved the wrong way. If you were to get the "body by Fisher" manual as mentioned, and read the window section you could do it.
