1 - 1 of 1 Posts
1969 Malibu L65/M20 Canadian built ///1972 El Camino all original
I am finally going to change the drums to disc on the chevelle. After reading a ton of posts I have a few questions about the conversion
I am changing manual drum/drum to manual disc/drum using over the counter parts.
I have spindles, backing plates & caliper brackets from a 69 Camaro.
1. Which master cylinder is best-1"(70 442) or 15/16(75-77 Chevelle)?
2. Will i have to modify the push rod assembly for the master or will it bolt right up?
3. Will the hard lines have to be changed?
4. Do i keep the distribution block and add proportioning valve to the rears?
5. should I get the slotted/drilled rotors?
I want to keep this simple and affordable as possible.
1 - 1 of 1 Posts
