Sometimes the only the left brake light works, other times the right and other times both. I've checked and in fact added additional grounds to the sockets themselves.
I suspect the problem is in the steering column associated with the turn signal operation. Work done by others when converting from column to floor shift (automatic). Hazard lights work but switch will not stay on.
Am I correct in my assumption?
Looking for a rebuild kit.
TIA
TIA
