1 - 15 of 15 Posts
Please help. Are the original SS wheels two or three colors. Have heard of argent silver and charcoal gray/black. Is thier another color on the backside? I read the jack base on the 70 is not black either. I thought it was black. Does anybody know?? Help!!!
Original 1970 SS wheels are 3 different colors. I've owned unrestored originals personally. They are argent silver and dark charcoal gray (inserts) on the front. The backside of the wheel is dove gray.
The 1970 jack base is black.....satin or low gloss. I've also owned original unrestored jack bases as well.
I just left the ebay site and looked at a couple restored LS6 cars. The trunk shot showed a jack base the same color as the back side of the spare. I also saw a "display only" repop jack kit with the base and jack mechanism painted that lighter color. Then I saw a original jack and these parts are black as you said. You"ve had the real thing,where do you suppose they get thier misinformation? maidwright
Different assembly plants had variations during the manufacturing and painting process so it's possible that there can be more than one right answer when it comes to restoring Chevelles. There were also changes during the year. There is a camp that argues that the inserts were actually black but mine were not. There are some who believe that some jack bases came in gray but that is not the common thought. As far as ebay cars go, many are simply restored incorrectly. I'll post some pictures of the truck of the 27 mile unrestored LS6 which show the backside of the wheel and the jack base as I described. For judging, the descriptions I gave are the most commonly accepted colors. I have learned there are always exceptions for these cars for sure.
If you use the search function at the top of the page, you will find a bunch of threads on this topic. Some of the better ones even give the paint formulas for the different paint manufacturers and colors. Depending on how correct you want to be, these wheels were shot with laquer paint back in the day. While clear coated wheels look better, they were not clear coated from the factory. Also, the satin black guys may disagree with the charcoal gray guys on the insert color.....I've never seen total agreement on that one. Some even say the satin black faded over time to appear like Charcoal Gray so 2 schools of thought there. You will find some interesting discussions using "1970 SS wheel colors" in your search. Have fun!
Here is an example from one of the threads using the search function that I found helpful:
Mar 12th, 05, 11:59 PM
Diamond Judge1
Hi Guys,
Here is what I know on the subject of wheel inset color. You are 100% correct, the stuff sold in a rattle can is way off.It is way to grey. I think if memory serves me correct, that color was developed by Brian Caudell when he started his detailing business and matched from an NOS Wheel he found. Like all things, NOS in a box does not always mean correct. What I used as a standard was a Unused Factory spare out of a 1970 Chevelle SS454, and that was actually a Black or Dark Charcoal Mettalic color. This wheel had not seen rain or sun, and had never been mounted on the car,it spent its whole life upside down in the trunk, so that should provide the best read on the correct color. When they are on the car, subject to sun and rain, they fade, flatten in color, and look a lot greyer after many years of use. It also loses the mettalic look first, somewhat because it was a very light coat of paint, and also it is sprayed over the light grey primer coat. Maybe someone out there with an unused spare out of a 1969 can confirm if they are the same, as I have not been able to come up with one to check yet. Tell you how I made my color, and I matched it up to the original spare and it was dead on. I took a Quart of Black Lacquer, and to that added 1 inch from a pint can of silver mixing Lacquer. Not real scientific I know, but you should be able to mix that up relativly easily. I am sorry, but I do not know of a rattle can mix, but some hardware stores might carry a charcoal mettalic paint that might be close. Good Luck!!!! Let us know what you find!!!!!
Jeff Dotterer
WOW! Those photo's are worth a thousand words. Is there a color # for Dove Grey. You've been great help. maidwright
Here's a few pictures of 4 AO wheels that have never had a tire mounted on them and have only been out of the box for pictures. My money is on a satin black / darker charcoal metalic finish as opposed to charcoal gray that comes in the spray bomb. I'll post a picture of the LS-6 27 mile car wheel too.
· Gold Founding Member
I was looking over my "AO" wheels again today and after seeing a couple of sets that I have AND seeing Mike's pictures plus reading the discussions,,,,
I believe there had to have been two different versions.
One version - black like Mike's and one version - dark charcoal with heavy metallic.
Of course that's just MY theory but I'm (almost) sure none of mine were ever black.
Dean, you could be absolutely right. Who knows if they changed from one paint supplier to another at different times during production. I'm sure they never thought people would be discussing THE correct color almost 40 years later. They just had to "BANG EM OUT" as fast as the could. The rims in my pictures are 2 4-19's and 2 4-20's date code, so whatever they were spraying that day is what these are. BTW, they don't look 1/2 as good as a restored wheel. The spray masking patterns were sloppy at best but again, a lot of the finished product coming off the assembly line was sloppy. Just my .02 on the matter
1 - 15 of 15 Posts
