1 - 20 of 28 Posts
I am currently restoring back to original a 1969 396 375hp iron head engine. Have been searching site for pics or illustrations I can use for reference to make engine factory correct. Looking for help. If someone can point me in right direction for pics, or recommend any books or materials so I can get the detail correct.
I have all the correct dated components. Alt, W/P, P/S, Distributor, Holley 4 BBL Carb, Winters Alum intake. Original chrome valve covers, Original chrome air cleaner. Want to get all Electrical, Vacuum, Fuel line routing and any other detail correct.
Will be installing back into my 69 SS with A/C car.
Thanks everyone....Appreciate your help.
No ac in the 375 hp 396 cars . Hadn't ever heard that
A/C was not available in any car with a solid lifter engine. To the OP, you can sure add A/C if you like, but you aren't going to find a deep groove A/C pulley. I'm sure you could use a standard pulley, though, but you aren't going to find any "correct" pictures of a L78 with A/C.
NO correct photos. NO correct AC deep groove pulley. NO correct three-groove crank pulley. Nor correct block VIN. A previous owner must have replaced the engine. Post the build sheet.
· Super Moderator
^^Thankyou^^.
· Gold Founding Member
Good lord people, back off. The man didn't say his car was originally an L78, he said he had a correct L78 and wants it to look as correct as possible in his 69 with A/C. Nothing wrong with that at all. Seems like an awful lot of grouchy old ladies on here lately...
Only a couple of folks letting the O P know what he's up against, that's all
Appreciate the replies. Info and help I was looking for to make decisions on direction of build. Yes not original SS. Just building to my flavor. Torn between keeping AC? or delete from chassis if going to be to much time and trouble trying to make work? Will take anyone's preference or opinion.
Does anyone have at least pics of correct engine bay pics w/o the A/C?
Your initial post stated it was an SS. You stated "Will be installing back into my 69 SS with A/C car." If not an SS not even necessarily an original 396 car at all. You are not up against anything since the car is not an original anything other than a Chevelle with AC. An Assembly Manual would be helpful.
The only grouchy old lady is ^^^. Everyone else offered honest comments.
67 Camaro SS/RS L78 M20 Convertible
1970 SS454 LS6 11 second street car
1 - 20 of 28 Posts
