1 - 2 of 2 Posts
Can anyone tell me, or give me advice about my wiper motor. When I turn them on at low speed, the work ok, and off they park. But when I put them on hi speed, the also park. In other words, only one speed, and they park in off or high speed position. Any clues?
Had A similar problem with my 68 Elky. Turned out to be a bad ground. Check the screw right above the switch that secures the dash bezel. It goes through a ground strap off of the bracket that holds the switch. It needs to be tight against the metal dash. Also check the nut behind the knob to be sure the switch is tight.
JD
1 - 2 of 2 Posts
