1 - 2 of 2 Posts
It's been almost a year, but the car is almost on the road again!!! I just have a couple of bugs to work out, one of which is this turn signal thing. They work fine except when I turn on the headlights the left indicater light comes on and stays on. When I turn on the left turn signal it works but is slow. On my test drive around the developement I did notie the indicater light dim down once , but it brightened back
I didn't do any under dash wiring, but did install a Madelectrical wiring kit [remote selenoid, headlight relays, etc.]
question.... where is the ground for the headlite ?? same place as the turn sig ?? clean the ground & the termails as this sounds like your not making good ground ... or when you rewired in the relays for the headlite you tied into the turn signal wire ??
1 - 2 of 2 Posts
