I have the core support out of my 72. I just put it in the loft. Let me know if you need pics, I can post a couple. I can at least look at them and see what order they are in. I kept the bushings in the right order so I wouldn't forget.If I remember right - starting from the top: bolt, large flat washer, cup shaped bushing w/ cup facing down, core support, larger bushing w/small end pointed up/fitting through core support hole, large cup shaped washer pointed up into the bushing (it may already be installed this way), frame, washer(s), nut. Hope this helps - B.
