The reverse switch and rod and bracket kit that mount on the Muncie are available as is the wiring harness. Here is a link for the switch and the hardware kit to install. The switch will plug into a cowl mounted connection that will be needed if your car is not a factory 4 speed car. It is drill plug and play but you will need to buy the harness too. Everything is readily available
