1 - 14 of 14 Posts
68 Chevelle SS Convertable
68 Build Specifications
Im a simple engineer that has a tendency to over engineer my hobby projects. This 68 build is not my first hot rod, I started in 76 with a 68 Chevelle coupe, then off with a 86 corvette and last was a 65 Chevelle coupe, but the 68 is by far the most extreme build I have enjoyed.
Found the car in South Dakota shed as a roller chassis, powder coated frame and substandard body restore. The complete car was in bins and no drive train. Sent it off for a complete body restore from bare metal and began building the rest of the car as I waited for the gem to arrive.
It was a challenging build in a small garage and all by myself. I had over a year to engineer the how I was going to assemble this car in a safe manor and to explore my hot rod bucket list of to-do’s.
Virtually all parts are either new, restored or modified to either fit as intended or re-engineered to fit properly.
Modifications
Drivetrain
Merlin II 555 Big Block
• Eagle Crank/Rods polished
• Lunati Roller Lifters
• SRP Pistons
• Hastings Rings
• Comp Cam-custom
• Moroso Oil Pump
• Holly EFI Sniper 550 EFI XFlow
• Holly HyperSpark Distributer
• MSD 6AL
• Holly Strip Dominator Intake Manifold
• Lemons 3” Headers
• 3’ stainless exhaust
• Stainless Radiator duel Fans
T56 6 Speed Transmission
• Input Shaft Diameter: 1.125 in.
• Input Spline Quantity: 26
• Output Shaft Spline Quantity: 31
• Transmission Speeds: 6-Speed
• Torque: 700 ft./lbs.
• Input Shaft Spline Count: 26
• Output Shaft Spline Count: 31
• First Gear Ratio: 2.66:1
• Gear Ratio (2nd): 1.78:1
• Gear Ratio (3rd): 1.30:1
• Gear Ratio (4th):1.00:1
• Ratio (5th): 0.80:1
• Gear Ratio (6th): 0.64:1
• G Force RCAEC2-6L80 Trans Crossmember
Differential - Mosier 9”
• Spline: 3068-72 A Body Housing and Axle Package - Yn case
• U-Joint: 1350 Series
• Spline Axles: - 35
• Bolt Circle - 5 x 4 3/4
• Studs - 1/2 x 3
• Tube - 1/4"
• Ring and Pinion: 370
• Tt: 35
McLeod Twin Disc Clutch Kit
• Rated up to 800 horsepower
• 1-1/8" x 26 spline
• 10" Clutch Discs
• Includes pressure plate, two organic friction discs, floater plate, adapter ring and pilot tool
• McLeod 1434004 Hydraulic Clutch Conversion Kit
Quick Time T56 Adapter Bellhousing
• Max Clutch Diameter = 11"
• Flywheel = 168 tooth or 153 tooth
• Full engine plate and grade 8 bolts
SBC 168 Tooth Billet Flywheel
• 168 tooth
• SFI 1.1 certified
• Manufactured from billet steel
Interior
• Custom Interior Carmel Leather
• 2017 Camaro SS power seats, heating, custom leather
• Alien Trunk custom Interior
• IDIDIT, Chrome Steel Steering Column
• Painless Wiring Harness
• Classic Dash Carbon Fiber Dash with Autocross Yellow gauges
• Power Windows
• Power Door Locks
Exterior
• BLACK - Daltron Nissan Code: 982100
• Shop-Line Hi-Gloss Multi Panel Clear JC661
Audio
BOSS receiver with Bluetooth
Front Fosgate 1000 W amp
  • 4 - 6.5” speakers ,
  • 1 - 10” SUB
Rear Fosgate 1000 W amp
  • 4 - rear 6.5” speakers ,
  • 1 - 10” SUB
Dash Midrange Fosgate 500 amp
  • 2 in dash 3.5” speakers
  • 2 in dash 3X7” speakers
Lighting
Front - OEM
LED - Taillights
Exhaust
3" stainless Steel
Suspension
Suspension and Breaks
• Front Wilwood-6 piston 140-9804-dr – 14”
• Rear Wilwood-4 piston with park 140-10012-dr - 14”
• Aldan American Front Single Adjustable Front Coil-Over Kit, 550 Lbs. Springs: AB2FHS
• UMI Front A-Arm Kit, 0.9 Inch Taller Upper Adjustable/0.5 Inch Taller Lower Ball
• UMI 402416-R 68-72 A-Body Rear Control Arm Kit
Wheel and Tire
VN515 TORQ THRUST RIMS
• Front 18”
• Rear 20 “
Awesome car (obviously..)!
I'm curious - how's that cold air intake working for you? I've been kicking around the idea of getting one myself.
You had me liking this car right up to the point I saw it had a black convertible top and body. The only thing that could be worse if the interior was black so you lucked out there. ;) Who in there right mind would have a black 68 convertible. LOL.... Nice wheels but then again I am partial.
After trying several this is the only that fit the 555 and hood.
Have
After trying several this is the only one that fit the 555 and hood.
Works perfect
Have the below if interested
717000
Based on the OP's Pics the Filters are sucking in Hot Air from the Engine Compartment
therefore they are not Cold Air Intakes IMO
A true Cold Air Intake takes/Sucks Air from infront of the car and directs it into the Carb
like my Ram Air one does
717001
717002
OP great job of the Rebuild on your Car
my first Chevelle i drove was a brand new 2 Door 68 300 Deluxe 307 ci PG of my Dad's
I love your Car's Interior Colour and the Black Paint / Top
Not a Fan of 18/20" Wheels on these old cars
To bad that Big 555 will never see the Drag Strip
Reactions: Leadhead
Nice 68! Black exteriors look great with 3 color interiors, Black, Red & Tan...Well White & Black but that's Two Tone (y) 🍻
You are 100% correct
This setup was a last choice for an air cleaner that fit.
The 800+ Hp available satisfies fine with hot air
1 - 14 of 14 Posts
