I need some advice with a couple of things that I have run into trying to change over to buckets.
First off, I bought some seats out of a 68 LeMans and the tracks seem to be slightly longer than the ones from the bench seat. Is this normal? Should I bend the legs slightly to fit?
Next, the seats seem to sit too far outboard when sitting over the holes in the floor. This causes the arm rests to hit the seats when the door is closed and the seat belt retractor will ride on the lower seat trim and wear it out. Should I use only one bolt in the inboard hole then drill a new in the front and another in the rear?
This car has the interior code on the trim tag of 765 158, so it has the Buick interior. It was built the first week of April in Fremont, Cal. Could the Buick floor pan locations be different?
Finally, will a Chevelle rear seat cover work on the Buick rear seat? I think it may be a bit narrower than a real Chevelle seat.
I know some body has the answers to the mind boggling questions, and I am in the best place to get the answers!
Thanks, John
Thanks, John
