1 - 1 of 1 Posts
I am installing new blue rear speaker wire. My car had rear speaker from the factory but the original wire was cut of on both ends. I found one wire clip on right X brace in truck and when I removed the carpet I found another clip. Did they use one or two clips to hold the blue wire on the X brace, and did the wire run straight up to the clip so you see the wire from the trunk. Thanks for you help.
1 - 1 of 1 Posts
