hey guys, I have a 67 el camino and here is my problem:
I was poking around with the multimeter yesterday trying to find out why my turn signals work, and my brake lights and hazards do not. I first tested the brake light switch. It seems ok. I has orange and white going into it (as the schematic shows). I followed the orange white into the column harness, and out. When tested the voltage on these two wires (orange has + white as -) with no brakes they have ~10.5 V running through them and with the brakes applied they have 0 V. (I believe that is because they become the same charge, thus voltage difference is 0, am I correct?) Anyway, these wires are for the dome light as per my diagram. Yet, after lots of testing they are the only wires which change charge with the brake switch. I currently have the tail lights hooked into the rear harness as per the diagram (yellow : stop/turn. brown: tail) Do I have a bad turn signal switch? Do I have a bad ground somewhere? (if so, where would you guess?)
I am running out of ideas for this problem, and it is the driving force behind "some people" wanting me to sell it. I would greatly appreachate it if any help could be lent on the issue, you might just save my truck.
Thanks alot, not just for any responses, but for all I have learned thus far in reading this forum.
Jeff
_______________________
1967 El Camino - 402 Big Block
1985 Porsche 944 (maybe)
Jeff
