Having to loosen the DS header to remove the already tiny oil filter is getting old!
Id like to run an oil cooler in front of the radiator and use a remote filter
Any particular order to do this, cooler first then filter or does it matter?
If I had to choose it would be to keep the filter in its current spot and put a cooler in to help with heat mgmt.
Both would sure be nice. Any downsides? Do I need to mount the filter same height as it is now, will there be a drainback issue creating a situation where theres air in the line?
Want the cooling system to be the best it can be. About ready to put a mech. fan back on, rather not though
