What rear came standard with the 327/325hp engine, a 10 or 12 bolt? Thanks for any input.
Rick
67ss bb
TC #326
But all it needs is a harmonic balancer.....
Definitely 12-bolt all the way. Ratios were 3.31:1 standard, with 3.55, 3.73, 4.10 optional; if you had a close ratio you could also get 4.56 & 4.88. They also used the rear frame reinforcement that the SS396 used.
The 327/275 was 10-bolt, unless you ordered the M20 4-speed (Saginaw 2.54 1st). Axle ratios for the 327/275 ranged from 3.07-3.73.
Thanks, I talked to a guy that has a Malibu, it was strippped to bare metal, ended up in a field in the weather. He wants to get rid of it. Guess I'll go out and look at it now.
Rick
