1 - 10 of 10 Posts
I searched all threads, but didn't see this, I saw a 67 with a metal shroud, not the finger guard . I know about the plastic shrouds. Question is was a metal one used? I found one but like to know if it's correct for HD cooling 4-row radiator. I can send pic of metal one if necessary, Thanks in advance.
Ed
The metal shroud was used with small block v8 and AC or heavy duty cooling.
Tom, A/C and HD cooling w/ bigblock? my friend has an elcamino BB with a/c, it has a plastic shroud
1966 & 1967 396 with AC, or HD radiator, or A.I.R. (smog), got the plastic fan shroud.
Small block cars with heavy duty cooling used a plastic shroud. This is with the 4 row radiator. I have two of the small block plastic shrouds.
mine is standard rad with metal shroud , small block
1 - 10 of 10 Posts
