2-3 years ago, I decided to fix the w/s washer. Replaced the valve, new hoses etc. When I put it all back together, the 4-tooth plastic gear that drives the washer mechanism broke. I didn't bother with it until today.
A few months ago, on an extended trip to Tx, I got a complete wiper motor assy from another 67 Elky(but could have been a 66, both were sitting side by side). Turns out the washer mechanism is completely different than mine. Among other things, the 4-tooth gear is metal with about a 1/4" shank and the cogs appeared to be approximately 1/32" shorter than the original plastic gear. I ground off the long shank to match the shank on the original and installed. The washer mechanism solenoid operates continuously, but (apparently) the shorter gear teeth does not move the lever far enough to advance the pump, then reset to the next actual pump cog.
Two questions: First, why does the washer work continuously? As far as I know, the wiring is correct. I jiggled the wiper switch with no change.
Second, does anyone have a source for the 4-tooth plastic gear without buying a complete unit?
Call me STUMPED!
Call me STUMPED!
