I am after an original look and fit set of bezels.
Does anyone make repop A/C bezels for the '67 Elcamino?
Dan chuck sells A/C bezels (p/n7876 & p/n7877) but they are not identified as 67 Elcamino.
I have the Chrome bezels that are designed for 67 Camaro. They will work if you want to grind on them and don't mind the chrome look. :rolleyes:
El Camino used the same dash as the Chevelle; 66 and 67 were the same as well if you can find a 66 donor dash.
I checked the Danchuk site and what I found were part numbers 6187/6188 for bezels.
http://www.chevelle.danchuk.com/02_01_dash_vent_bezels.html
They show 66-69 and I'm not sure that's correct. Searched for part numbers you listed but came up blank.
The only bezels that are avaliable are the ones you have that are chrome. The originals pop up on ebay from time to time and go for around 100-125 a set. If you run across a set that need some repair, James Hinshaw restores them.
John Weaver
