hey there everyone,
figured i could ask the best community of people for some knowledge on this subject... I am curious how much my 1967 el camino custom is worth. It is not quite done and i am contemplating if the things i have left to do or are planning to do are worth doing. hope that makes sense. here goes the cars details. It is a california car with original a/c [now in boxes]
motor: from a 1972 chevelle - 402ci [414ci now] w/ oval port iron heads[built] - pro comp pistons-engle camshaft/lifters - comp cams pushrods/guideplates/rockerstuds - full roller rockers - stainless steel valves intake/exhuast both enlarged - weiand aluminum stealth intake - edelbrock 650cfm carb - msd billet distributor w/H.E.I. - edelbrock aluminum water pump - moroso oil pan [kicked out/trap door/baffle/windage tray] - Headman headers -Magnaflow 2.5" polished stainless steel exhuast[hidden exit behind bumper] - Edelbrock finned tall polished valve covers w/ 14" air cleaner - k&n air filter - factory remote reservoir p/s pump - powermaster 1wire alternator - taylor wires and wire loom/organizer
Transmission: - TH400 rebuilt with a 2" deep pan
Rear End: - 12 bolt - 3.07 or 3.31 gearing - Eaton limited slip posi - USA alloy axles - all stainless hardware
steering: factory: tie rods/centerlink/pitman arm/14:1 steering box [3turns lock2lock]
suspension: front: Global West tubular upper/lower control arms w/ Del-A-Lum bushings [g-plus] -stock spindles- Hotchkis BBC 2" drop springs - Edelbrock IAS shocks [grey] - 1 1/4" sway bar
rear: Hotchkis boxed lower control arms - Hotchkis 2" drop springs - Hotchkis adjustable sway bar - Edelbrock IAS shocks [grey]
brakes: front: wilwood 4 piston - 12.25" drilled slotted rotors - stainless flex lines
rear: wilwood 4 piston - 10"[?i think] drilled/slotted rotors w/parking brake provision - stainless mounting hardware to the rearend - custom stainless steel bent hard lines with stainless flex section for either caliper - stainless steel sheethed cable for e-brake - gloss black e-brake cable brackets
rims/tires: 18x8 - 18x9.5 Centerline Meteors [polished aluminum] - 255/40/18 & 285/35/18 Nitto NT05
other: updated modern fuse panel 12 circuit[e-z wiring] - everything soldered, shrinktubed, dressed with convuluted tubing and then taped to make clean tight looking loom - had to add reverse lights/nuetral safety switch - integrated viper 1/4 mile range alarm w/ remote start - integrated stereo system - used all new deustch weatherproof connectors where needed for ex. the dash has been redone and is removable with the one clip release for the electrical - optima red top battery
body/sheetmetal: replaced all 4 floor pans - covered with rust bullet - dynamat entire rear cab, floor and firewall for now - rechromed bumpers - steel ss hood - a/c delete kit [fiberglass]
interior: replaced the ss dash with knee knocker tach with covans classic plastic blank - used autometer sport comp gauges all electric, tach and speedo are 3 5/8", volts/oil/water/fuel are 2 3/8", all gauges replaced green leds for backlighting, rewired/loomed with modern connectors - factory bench seat black vinyl - factory ss steering wheel
owned but not installed
- afco aluminum radiator with electric fan and custom shroud
- CUSTOM STEREO [all prewired/fused] pioneer double din touchscreen nav headunit[need to fab a center console for it]
-infinity kappa perfect 6.1 component setup
- kenwood 1000w mono amp
- kenwood 600w 4ch amp -
- pioneer 10" typer r sub [wont be using, magnet is just too big, gonna look for a shallow mount self powered sub i think]
- lokar l.e.d. gear indicator bezel/hardware[needs to be integrated to dash if i keep th400]
- brand new rubber body mount bushings w/ hardware
- brand new carpet kit
- firewall steering column foam
Plans to complete:
-Order/install mitsubishi lancer evo S.E. recaro seats
-Order/install grant steering wheel [something more suited for auto-x]
-order/find/install T56 transmission [everything that goes with that - bellhousing/clutch/flywheel/pedal setup/hydraulic clutch setup/driveshaft/x-member/possible trans hump modification/center console fabrication that blends into rear panel for the rear cab for stereo equipment
-want to make the smuggler compartment hinged/motorized/lockable?
last but not least paint/linex the bed
is it worth finishing it the way i am planning on? whats it worth now? should i do everything except paint. i am open to all opinions and comments, thats the whole reason im posting here... i will post some pics in a bit, car is black by the way, there are some pics on here somewhere i think rim and tire pics or el caminos?? anyway thx for the input hope it isnt too long just so indecisive and i know what i WANT isnt necessarily going to be the best choice unless i plan on keeping it forever. by the way the car handles amazing and i feel like it would be complimented well by being able to bang gears and not get thrown around like a rag doll in side a pinball machine. car has no roll at all. thx again
-brett
What value do you have in mind? ComPorte and as it sits. How much do you think it will cost you to finish?
to finish it the way i think it should be done or the way i had set out to do it from what i had in my head, tranny, interior, modded smuggler box, linex bed, and paint if i really cut corners maybe 15k....
what do i want to get for it finished... man... i would hope for at least what i got in receipts, im not really sure... thats kinda why i am asking on here, will be posting pics tonight, have been on the road for a bit.
Pictures please. Can't say much without pictures.
