Well, after ripping out some old wet insulation on the interior to get ready to pull the heater box and core, I connected the hoses together in the engine compartment. Then I had to practically drop my right wheel well... Ok I loosened up the bolts and used a couple of wooden blocks to pull it away from the firewall. I exposed the bolts buried behind the wheel well only to learn that the knucklehead before me never put the bolt on the heater box screws.
Ok, everything is rusted... so I'm ordering new stuff. Guy on the phone tells me the heater blower is tucked up between the firewall behind the wheel well. I did not believe him at first but sure enough there is the fan.
Question for the group. Where is the power to this heater blower? Where does the wire come from? What color is the wire? I do not see any wiring to the blower motor.
My wire on my '67 is yellow with a female boot connector. The yellow wire is running out of the wire harnes from the engine compartment side of the fuse box.
