1 - 13 of 13 Posts
Super Moderator
I recently listed a brake/clutch pedal assembly for sale and listed it as 64-67. This unit came out of a '65 I'm parting out. A potential buyer wants to make sure it would be a direct bolt in for his '67 and before we make the transaction we want to be sure it will work for him. I thought all such assemblies were the same for all 64-67 Chevelles, but after a bit of inconclusive research I'm not sure any more.
Will a '65 clutch/brake pedal assembly directly bolt into a '67?
OPG lists a lot of the clutch z bar parts for 64-67. I can't find anything else about it.
Super Moderator
When it comes to the pedals they list one set as 64-66 and another as 67 only, thus part of my confusion. I can't see what could be different between them, but there must be a difference or they wouldn't have tooled up two different sets.
Rich all the info I found said 67 is different than 64-65
Exactly what I have always seen. Than I notice OPG shows the zbar for 64-67, different for small block and big block. I was thinking the 67 zbar was different than the other years too, guess not.
I don't understand what happen at GM in 67 to make things a little different at the pedals.
Super Moderator
Could the use of a dual circuit master cylinder and collapsable steering column which both arrived in '67 have anything to do with it?
Very possible, but I have no idea.
Yes the collapse-able column is difference maker. The bracket that supports them to the dash & swivels the pedals was modified for the 67 model year. Hence, the offset on the brake pedal for the 64-66's wont clear the steering column support in a 67.
I have tried to use the clutch pedal from a 64-66 in a 67, but it would take some mods...however the 64-66 brake pedal is a no sale in a 67.
Not sure about the 67 pedals in the 64-66s, but I doubt they would work.
The attached pics show the offsets of the brake pedal swivels. (courtesy of Dale M.)
Here are a couple of more pics that I took of the brake pedals, including a close up of the swivels.
The 64-66 pedal is on top in the full length shot.
1 - 13 of 13 Posts
