1 - 10 of 10 Posts
Silly question: on your '67, do your brake lights work whilst either indicator is on?
On my '67 they do not, just curious if it's a factory thing or someone has had their busy little fingers into something.
Administrator
It is impossible for both to work at the same time, it uses the same filament in the bulb. The turn signal switch cancels the brake light on the side it is engaged when signaling a turn.
Maybe I didn't word it correctly ;)
You're coming up to an intersection to turn left, you indicate and apply the brakes at the same time and the LH Indicator/Brake lamp flashes.
Does the RH Brake light stay illuminated if you LH indicator is going and your braking, or does it go out :confused:
Administrator
When turning left the RH brake light will be on, when turning right the LH brake light will be on if the turn signals are engaged.
Thanks Phillip, I obviously have a problem as neither brake lamp stay illuminated when either indicator is on :(
I will investigate on the weekend :)
Anyone else had this problem?
Administrator
Do the brake lights work with the turn signals off? If the 4 way flashers are on what happens when you apply the brakes?
Most likely the tail light socket isn't making a complete ground where it plugs into the tail light housing. I'd start by cleaning up that area.
hi Jim, well as some have said is it just the left side, then maybe its a bad socket if it doing this on both i check sockets both sides wiring to and and check all grounds if you think its a ground make sure the engine to chassis ground is there if not make one up start fresh, dumb question are the bulbs in correctly it would do the same. if all is good back there go foward, on my 67 chevelle my lights were working good, when i restored my steering column and replaced the turn signal switch all the wires in the flat harness were all shaved of insulation was just a matter if time till i would have had a problem
also have you checked all lights reverse as well as interior lamps, did you check to see if you have front turn signals as well as parking lights?????? well hope this helped good luck and keep us posted
1 - 10 of 10 Posts
