caeleb, Replacing this line with the body still attached to the fram is a real pain. It is a little easier if you unbolt all of the frame mounts on the passenger side and jack the body off of the frame slightly for clearance. I think most of the major companies making the lines are probably fine. I believe mine was a stainless line from Fine Lines and it fit well. Good luck.
Tom
