The 66 SS scoops are body color for bulk of the scoops, however, they have inserts.
The inserts look like they have 3 levels of polish:
1. the outer lip outline
2. the inner lib outline
3. the small "up-n-down" bars at the center of the inner outline.
These seem to be the only polished parts of the inserts. The rest of the insert seems to be flat black or semi-gloss black.
Is this correct?
Is this correct?
All chrome (or polished) except the inners of the 'up-n-downs' and between the inner and outer lips. The outer bars of the up-n-downs are chrome.
just be aware that the scoops and insert are both pop metal or dicast metal. which means they can be brittle. the inserts where chrome plated, you can lightly dust black paint on them then quickly rub the paint of the high spots with lacquer thinner
