Hyper Blue was one of my choices. I really like that color. I only chose Admiral as it is just a touch darker and I think iit has just a little more purple in it.Admiral blue - nice choice!! Almost the same color as my SS - hyperblue metallic
you can tell I am a fan of blue - here it is parked next to my Marina blue 1966!!
Untitled by C4RACER, on Flickr
and btw Senna - I am also in San Jose - out in the Evergreen southeast foothills. Shoot me a PM if you need some help at some point - would be awesome to compare notes. I just picked up this '66, but also have a full pro-touring built 1971 Camaro.
Thank you Hotwire. I'll check the tie rods for sure. A Crown Vic drive shaft would probably be a WAY cheaper way to go. However, I might just have one built with a CV joint to help reduce vibration from angles. I would also have to check the ends on the crown vic driveshaft. I just don't know enough about drive shafts. My trans is a 4L70 and the rear end is a 9 from Quick Performance. Are the ends the same?That color looks amazing, can't wait to see it completely sprayed! I've always lusted after Corvette electron blue metallic, still have yet to get it on a car though.
Be sure you about have the tie rods hitting the oil pan at full lock, it's a pain to get the pinion angle right if you don't. When you measure for your driveshaft if it's 55.5" center to center, go to your local pull a part and grab an aluminum shaft out of a crown vic. Damn near better than anything you can purchase from the aftermarket right now. If you're running short tires and a high gear you'll find the critical speed of normal driveshaft too quick.
https://flic.kr/p/2m1xpQe
Sweet. Thanks Jeff!!!Looks amazing!! You can google these part numbers, they're for the factory blockoff plates. Need short 10mm bolts to attach them to the oil pan.
24261712 - starter shield
24261713 - flywheel blockoff plate
Yes, matte the dash. Mine is gloss and it can be annoying due to the glare.
