2.5 days of work and the American Autowire Harness is in. Was a bit easier than I thought. Wiring left to do:
- Doors - Get power, power windows, power locks and two sets of speaker wire. I already had holes for everything except speaker wire, so just need to enlarge
- Main power - Just received my roll of 1/0 welding wire today, so I can get that done. Unfortunately, my kit from American Autowire didn't have the MEGA fuses or block. I bought it so long ago, I doubt they'd send me one. I have a circuit breaker I can use, so no major loss. Routing the cable from the trunk should be fun.
- A/C binary or trinary switch. The binary switch Vintage Air sent me is female and needs to be male. Again, bought it a long time ago. Probably just have to buy one. Suggestion on binary vs trinary? The ECU already controls the fans and turns them on at 207
- Halo headlights. Gotta find a spot for the controlers
- Courtesy Lights. I'm not using the factory ones, but LED strips instead. I'm going to wait 'til I make sure everything works to tie the harness up and fabricate mounts for the LED strips
Pictures:
Had to cut a space next to the fuse block for the pedal wire, OBD and a couple other things:
Rear harness running behind the II MUCH filter:
Battery mount in and battery installed (delivered today):
Switches and the only left over wires. The one switch without a cover is for locks and the only place it would fit. The round switch on the bottom is for the wipers:
Only a couple engine bay wires left:
