Hello,
This is my first post here. Great forum and since I finally got myself a Chevelle yesterday I'm glad to be part of it.
My car is a 1966 base car, no power anything. It has a small block - supposedly a 305 (why in the world???). I am looking to add power steering with the Grand Cherokee box. I have to get everything since the car came as manual steering.
Can you guys look at my parts list and tell me if you think these would work, or if there is anything else I'd need?
Rockauto:
GC Steering Box Lares 1353
Rag Joint Lares 200
Power steering pump Lares 2033
Power steering reservoir cap Dorman 82581
OPG:
Crank Pulley, small block double groove CHT9603
Power steering pulley (says 64-72 keyway fitting) CH20006
Lower/main power steering pump bracket SFL0001
Small block power steering pump adjustment bracket SFL0004
Power steering pitman arm C220248
Rockauto lists several belt options. Anyone know which part for the belt I would need? Also which PS hoses work?
I've read the center link has to be replaced to use the power steering pitman arm? I can't tell from OPG website which I would need?
I appreciate any help. I have read multiple threads on here that cover swapping the box for the GC box, but since I'm starting from scratch I thought I'd ask for input before I go ordering things.
Rockauto:
Rag Joint Lares 200
OPG:
