How do you remove the light switch aasy. from a 66 sweep dash?
Bob C.
70 Malibu
TC Gold Member #169
N.E. Chevelle & El Camino Assoc. #085
[email protected]
bob70,
I don't remember if a 66 is same as a 64,I just put one in couple of weeks ago.There is a little pin(small button) on the switch assembly that must be pushed in to allow the shaft to slide out the front.Once the shaft is out its a breeze,Just unscrew the retaining washer and remove assembly from under dash.You can see the button on the new switch easily( have to feel for it while in dash)
I replaced mine cause the tail lights were on then off at will.It turned out to be a loose connection at the place where harness plugs into flat cable that runs under carpet.
later Tony
How do you get that retaining nut off? does it require a special tool? I'm assuming it's the one with the two small holes in it.
