The interior ctsy lamp on the back of the console is supplied with unswitched voltage and activated by grounding switches at the door jam. My two interior ctsy lamps, above the kick panels, under the dash are ignition switched and again activated via the grounding of the door jam switches. Is this correct??? I thought they both would of been on the same circuit and not seperate with one being ignition activated. I am getting the car back together after 8 years and having nightmares with poor grounds because of painted surfaces. Thanks in advance, Bill
Thanks for the reply. I didn't realize there was a orange lead on the fuse box that I could switch from one position to another. I will check it out when I get home tonight. I would prefer to have the lights by the kick panels battery fused just like the console light. Thanks again, Bill
I switched the connector last night and the interior lights now work perfectly. They now all work off of battery fused. Thanks I would not of figured this out without your heads up on the connector at the fuse box. The people on this site are the best!
Bill
