luttys chevrolet parts in pa. sells them, they actually have a threaded stem with a nut on back to install, I use them for when I take dash boards apart to sandblast steel frames and then put them in dash to reassemble, but thats what they are is for the 66 grills, mike. www.luttyschevy.com
Hinshaws Chevelle Parts has the correct grille rivets in stock. 336-586-0802 in Elon, NC.
don lemek said:
I am looking for the exact original, hollow stem rivit. You use a rivit setting tool to install.
As above post says Hinshaws sells those original type rivit .. using them right now
