So heres a photo of my 66 gas tank mockup.
I put two foam blocks on the trunk, then the foam pad.
Then set the tank straps in place and set the tank in place.
Got a longer bolt and worked the straps into place and into shape.
Finally, took the straps loose and glued the two tar paper strips that go under the straps onto the tank.
Installed the sending unit and pickup. Took it apart, put the tank back in the box and will put some spray paint over the epoxy primer on the bottom of the trunk.
