Hi guys,
No pictures to post yet, because I don't have the trans. 3.27 1st gear from MDL. hydraulic clutch. I'm going from a powerglide. I have a 3.07 12 bolt in there now, and may change gears and a truetrac.
i'm thinking about the offset shifter
and the bench seat oval boot/retainer ring. also wasn't sure about which shifter handle, they originally spec'd out the camaro handle but then recommended the tri-5 handle because they said the tri-5s were all bench seats so that should work. my seat is all the way up.
