installing carpet has anyone any hits on the best way to do this[cutting, measuring glueing?]I bought the carpet through paddock
If you bought molded carpet it is a snap! Lay the carpet out where it is at least room temp. for a couple days. It will then fit right in. Mine came from NPD aand it fit great!! Iam taking for granted that you have the seats etc. out? I only had to trim a little next to the scuff plates. You shouldn't have to glue it. Good luck any problems e-mail me. Slime
Steve
Get your carpet layed out where it goes with all your seat mounting bolts and seat belt bolts in place and cut an x on bolt head and push down,this is easier than trying to find the holes later!
tye, if you bought the premolded carpet the only cutting should be for the two balls in the floor that the gas pedal snaps onto. Ther should be a hole with a grommet for the low/high beam switch. Good Luck, Rick
