went to the body shop today to get the rusted one removed and put new one in my question is will it be okay to leave off the two braces that go from trunk to quarter panel because i have to put quarter patch panels on both sides of the car they were done long ago now they need to be re-done again thanks.:hurray:
I believe it will be fine I just put a quarter skin on my 66 and a trunk pan. and the pan was done first then i did the skin and welded the ext from under were they made contact plus i think you want to get them right up under the pan
If you dont mind what did they wack you to install the pan my brother and i were trying to guess. Plus did they weld in the gas tank braces and the braces from the body mounts to the bottom of the trunk pan and how did they finish the weldes with primerand then undercoat or paint?
yes i wood like to the pictures of your car. i have been collecting parts for my car since i got it last june now its time to put it back together.:hurray:
I would like to some pics also. 1200. doesnt sound that bad but I take it your doing it all yourself, I see you have a metal shop in ct were about. I am in new haven.
still waiting for pictures of the work you had done on your car so i can get a ideal on what its going to take to do the work i need done thanks.:hurray:
