I have a 66 Chevelle SS with the 2 spoke original black plastic steering wheel. I have the horn ring and horn cap. I am missing everything else with the exception of the turn signal cancelling cam. I think I have most of the parts, however, I need a diaghram to show me how it goes back together.
I sent the pics and a very detailed description to Harold yesterday. Maybe he will stop in and post them. If not I'll post them soon. I'm in work now and the pictures are at home.
Here's what I sent to Harold. Any ?'s, just PM me. NOTE: the cancel cam, spring, and the horn cap are not shown. I assume you already know what they look like.
Tom
I'll try to explain it in words starting from the cancel cam on the inside of the column. Start with the cancel cam with the horn contact on it and put that on the shaft with the contact pointing towards the driver's seat. A spring goes on the shaft on top of the cancel cam. The steering wheel goes on next with the horn contact on the cancel cam going through the steering wheel. Put the nut on the shaft at this point. The parts in the picture of the metal and the white plastic that I sent you (pic# 1) goes on next, metal first with tabs up. The white plastic next (see pic 3 for parts on steering wheel). The horn ring goes on next. There is a plastic ring with three holes in it that goes on next. It has 3 plastic stand-offs that go through the horn ring. The 3 phillips screws hold the horn ring to the steering wheel (see pic4). The horn cap goes on next. That's it. Let me know if that makes sense.
Tom
Thanks Tom,
Pulled the fake rosewood off today and put the original back on, looks 100% better, the components were different and would have been guessing without your help.
Need a horn diagrasm for a 66 chevelle of parts that are inside the steering wheel. All other parts as to wiring and relay is hooked up correctly and i have a new relay. Just need a diagram of horn parts on the wheel.
Re: 66 chevelle horn diagram of parts on the steering wheel.
need a horn diagram dor 66 chevelle as to how the parts are assembled on the steerin g wqheel so there is a ground when the horn button is pushed down.
Hi Harold, this is like deja-vu all over again Do a search for 66 horn. I had replied to your question about this on Oct 10, 2005.... Check it out again and let me know if it makes sense. You may want to buy an assembly manual. There's a bunch of good diagrams in it that will help with the assembly of your car. Best $30 you can spend.
The horn question for a 66 I can offer some info on, as my 66 came without at working horn.
I have the two spoke wheel. I bought 3 horn parts kits. None fixed it.
There should be pictures here somewhere, but I would buy the shop manual.
I replaced the turn signal cancelling cam, a major part of the horn. Still no horn. I had power at the spring loaded plunger and if I crossed it to ground with a screwdriver the horn blew....
After six months of messing with it, I figured out that power comes to the horn button via the wiring and to the spring loaded plunger that extends through the tube part of the cancel cam and then through the hub of the wheel It then contacts the against the underside of the belleville spring, (round spring disk thingie) when the horn is pressed.
The round disk thingy goes convex side up. The outer edge sits in a recess in the top of the steering wheel. The METAL PORTION of the recess in the steering wheel where the spring disk thingie sits is the ground path! Mine was nicely painted by the prevoius owner, insulating it. 30 seconds with a pocket knife and I had a horn!
There is also a ground wire that makes the ground across the two parts of the rag joint at the steering shaft connection that need to be clean and conducting.
A picture would explain it better, and if I find one later I will try to make it available.
And make sure the metal part of the steering wheel hub is clean so when you push the horn button, it grounds and blows the horn. It took me a year to figure this out on my 66.
Hello.
I am also having trouble with this on my 67 with the standard steering wheel with the buttons in the wings of the wheel.
The wheel has the contacts in place with wires coming out. Everything was gutted from from the hub. All that remains is the white switch assembly and a a black plastic cover.
Not sure how this gets put together. I am about to purchase the 3 piece horn kit, but could use some help in what this should look like. I did see the three photos below, but still not able to visualize.
Is anyone aware of a diagram of how this goes together. Not sure I have all the pieces.
thanks
Scott
Norm,
thanks for the time. Here is a link to the NPSD page that shows the 3 pieces. the item number is C2800 50B http://npd.dirxion.com/WebProject.asp?BookCode=cev09flx#. This is the best way I could get you a picture. The cam is very different as you will see on the adjacent NPD page.
ss
Thx for the photo's. I just put an original wheel back on my 66 Beaumont and the photo's saved me a lot of time. (When I first purchased it about 28 years ago it had an after market wheel.)
Thx again...
