I own a 66 chevelle hardtop tht needs a frame. I was wondering what all frames will fit,I've heard a lot of different things. I was wondering if a pontiac or buick etc frames will fit. I've been told some 4 doors frames will.I dont mind doing some work to get bumpers etc. to work as long as the body will bolt on. thanks
[This message has been edited by TROY (edited 01-30-99).]
I used a '66 4 door frame for my two door '66. I am going to have to weld a clutch bracket on it, otherwise all mounts line up. I have another 4-door frame with 10-bolt if interested.
Discussion Starter #3
Bud where are you located and how much
I'm in Rome, GA. Will take $150 for the rolling frame. This includes 10-bolt rear end, front suspension and steering gear. The frame still has the four-door body on it plus gas tank. Front sheet metal, steering wheel and dash gone. Give me a call @ 706-295-2244 in the evenings if interested or I'll check this sight for a reply.
Discussion Starter #5
bud
wish you werentas far away as you are,im in maryland. ill keep your number if nothing else comes up
thanks
