1 - 9 of 9 Posts
You can cut a hole in your automatic plate, if you have one. The plates are the same except for the cut out.
You can also buy one from OPGI. I modified mine. Really easy to do. The cutting depends on the clutch set up you are using. I took a look at the OPGI catalog to get an idea of where to cut.
When I put the stick in the 66, I bought the gasket and used it for a template to drill the hole.
Banned
1 - 9 of 9 Posts
