I have a 66 Chevelle and were rebuilding the 396. Summit forged engine kit with small dome, heads are 1966 closed chambered oval ports, the intake is a stock cast iron Holley, factory manifolds with 2.5 exhaust. 4 speed, 3.31. either a 3310 or 750 double pumper carb.
I have 2 cams available to use that are on my shelf. One is a
LUN-60203 Hydraulic flat 1800-6,200 227Exhaust at 050 233 Duration at 050 inch Lift227 int./233 exh.Advertised Intake Duration268Advertised Exhaust Duration276Advertised Duration268 int./276 exh.Intake Valve Lift with Factory Rocker Arm Ratio0.542 in.Exhaust Valve Lift with Factory Rocker Arm Ratio0.554 in.Lobe Separation (degrees)110
Or a Comp solid roller
11-770-8 Cams Xtreme Energy Camshafts-11-770-8 Mechanical roller 2,200-6,200Intake Duration at 050 inch Lift236Exhaust Duration at 050 inch Lift242Duration at 050 inch Lift236 int./242 exh.Advertised Intake Duration274Advertised Exhaust Duration280Advertised Duration274 int./280 exh.Intake Valve Lift with Factory Rocker Arm Ratio0.639 in.Exhaust Valve Lift with Factory Rocker Arm Ratio0.646 in .639 int./0.646 exh.Lobe Separation (degrees)110
Would this roller even work in the 396 with the manifolds and small cubes?
Thanks for any input
