1 - 2 of 2 Posts
Hi,
Does anyone have know the spec for this thermostat. When tested in hot water mine starts to open at 150 deg F and is fully open by 180 deg F. Does that sound about right? What do the books show is the correct temp therm for that engine?
thanks,
DWR
Starting to open at 150 deg f is kinda early,sounds like it's a 160 stat or the 180 stat is starting to open a smidge early.
Get a new 180 deg stat you that will work fine for your 396.
Scott
1 - 2 of 2 Posts
