Has anyone removed the choke and the flap from this carb? If so, how did you do it?
remove the two screws that hold the choke flap (inside carb), be really carefull not to drop those screws down the carb. Then pull the flapper up and out of the way. Then I forgot, but you have to remove the side lever on the choke side, then it slides out from the side. Take pics if you get lost, but it's straight forward.
The screws that hold the choke flap are peened over. You will need to file the tails off them before you will be able to screw them out successfully.
