Does anyone know if I can replace just the felts that run up and down inside the vent window assy. for the door glass? thats the only peice of rubber that hasnt been replaced, and i cant find one!
thanks
Heath
Heath, yes, it has a VERY tiny screw at the top......the felts are available at NPD, I always ask for Derik at the Fl distribution center. not really expensive...now then the bad news is....it will be a pain unless you remove the quarter window....BUT it can be done without doing that. Just take lots of chill pills.:D
Thanks, Ill give them a call
when you say remove quarter window do you mean the vent window?
ill most likely have that part out to achieve a proper paint line when i spray it!
thanks!
yes, the window assembly comes out with as a whole piece, two screws inside door panel and two in the front door frame. Also a mystery screw just below the window vent in the top of the door that holds the "vent window assembly" in place as well. and of course while you have it out replace the vent window rubber too when the paint job is taking place.
