I want to change my 65 from drum to disc. Is there a direct bolt on from a later model GM car? I am sure this has been talked about before, but I missed it. Thanks.
Donor cars for 68-72 I think you can use.
73-74 Apollo
67-72 Buick Special
67-69 Camaro
67-72 Chevelle
70-72 Monte Carlo
68-74 Nova
67-72 Olds F85
73-74 Omega
71-72 GMC Sprint
71-74 Ventura II
69-72 Pontiac GranPrix
I have spindles and caliper brackets if you are interested. Email me for details.
DG
Springfield, Ohio
70 Chevelle Malibu
www.genxspeed.com/dg/chevy.htm [email protected]
TEAM Chevelle Member #0086
Genx member (Founder 4 Ohio)
eBay username: dg98adams
One thing you also need to get to make a conversion complete is a set of brake lines. I suggest contacting Right Stuff Detailing or Ground Up (a distributor of RS). They can send you a set of prebent lines, hoses and even a proportioning valve. If you need any info just contact me I've done a swap on a 65 and can even tell you what hoses you need for the front to keep the correct length and not have to change the factory brackets on the frame.
J.J. Fig
MCC member #256
http://www.clark.net/pub/chevelle/mcc.htm
Hey Jax,
Don't forget to change the master cylinder to a disc/drum dual pot type, you'll also need a proportioning valve. If you're going to use a wrecking yard as a source for your parts suggest you buy the whole spindle & disc sub-assemblys from the same car. Then rebuild the calipers. Be sure you have the discs checked for out of round and proper minimum thickness. Did it earlier this year, if you need more details e-mail me. mgg
