Guys,
Do I need to remove the windshield in order to remove the Dash Pad from my 65 Chevelle?
If not are there any hidden screws I should be aware of?
I also need any tips on gauge bezel? removal.
Thanks,
Jack
Jack Gauge Bezel is held in with the screws around the permiter of it(like on the flat parts) you'll have to drop the column a little bit to get it out too. Dashpad comes off without removing the windshield. There are a whole bunch of clips on the underside of the dash that it attaches with. I'm sure others will elaborate if im not making sense!
good luck!
Russ (or Steve)
1965 Malibu 283/PG/A/C
Now 283/TH-350 soon to be 383/TH-350
My Homepage (Updated 5/31/2001)
Team Chevelle Member #71
The dash pad is held on with nuts (not clips). The pad it's self has studs that fit through the holes in the top of the dash.
Yes, there are a whole bunch of them and even with everything removed from the front of the dash, it's a pain to get to all of them!!
You don't have to remove the windshield.
Wes. Vann
Technical Reference section
Gold Member #5
