1 - 2 of 2 Posts
Hello everyone. Just put a new small block with 100 amp. Int reg. Alternator. Also a new engine harness and forward lamp harness for a 65 with hei and int reg. Tried to hook up the alternator. The alternator is for one wire . There is four prongs in the alternator. The pigtail at the end of the new harness has two prongs will not fit . Is there an adapter that i can get to solve this problem. Thanks mitch.
Well, the way I see it a one wire alternator wouldn't be a one wire if you could hook up 4 wires or 2 wires.
My one wire is exactly one wire that goes from the alternator to the battery.
I have a black plastic plug that fits the other connecting spot.
1 - 2 of 2 Posts
